MAP sensor
  Clio 182
Been having a running issue at times with my 182 and wondering if anyones had the same?
MAP sensors
Went out to the car last night and got some live data readings. The code only stated MAP sensor so ran that alongside coolant temp etc. All temps as expected but the MAP sensor reading is off. Basically it's reading 103mbar at idle, when driven and even with it unplugged which makes no difference.
Would this indicate the ECU is seeing the MAP sensor so voltages etc be ok and the sensor itself has gone and its reverted to a default setting??
  Clio 182
Update...
It looks to have the wrong MAP sensor fitted. Will confirm wiring is OK but looks like a sensor needed
