Master cylinder leak damaging brake servo?
  Ph1 172.
I posted the other day that my brake pedal had gone rock hard and couldn't be depressed. it was intermittent and didn't do it every time I braked.
I took the car to a garage. They have advised the master cylinder has leaked, damaged the brake servo and both need replacing. If they do, I will get down a breaker and get the parts as I don't fancy the new prices!
However my question relates to if this sounds plausible given it was intermittent and not all of the time. They have also quoted 7-8 hours to complete the work.
I just want confirmation before I commit.
  Ph1 172.
It turns out the garage's diagnosis was correct, the master cylinder is leaking and the servo wasn't 'not working' however their fix, which included the servo removal maybey wasn't.
I asked my girlfriend's dad who is a mechanic and he spoke to his mate who is a Renault specialist, who advised it was unlikely to be a damaged servo and that he'd never had to replace a servo and it was most likely the vacuum pipe or one-way valve.
New servo arrived. We swapped the valve over and I had servo assistance! However, the servo was FULL of brake fluid. We used a vacuum pump to remove 600ml of brake fluid from inside the servo. It has evidently been going on well before my ownership. However it must be a very slow leak as the brake fluid sensor works and hasn't come on in the 8 or 9 weeks I've owned the car.
Dannyeff
  Clio 182 trophy
where did you order the part from?
