Megane Head on a williams
Ok im swapping my williams head for a megane head. i hear it needs machining for the dizzy to fit. anything else needed for it to fit on?
Ill be sending it off to have headwork done before fitting it to my car tho.
Craig
you will need the dizzy housing machined out, but thats super easy.
If your running the std ecu you'll have to adapt the std inlet manifold to run the std williams components and ICV and TB. The williams manifold will not bolt up to it properly and run.
If you need anything just PM me.
Why?
You're not going to get that much more benefit running the megane head over a williams item...more hassle than its worth especially when you could spend money better in other places IMO.
