mf2 and megasquirt ignition driver
Car  black 3 door clio 1.2 16v
hiya guys ,for the time being untill i can fully afford standalone managment would this be possible to run my low boost turbo??
use an mf2 mappable fuel injector to controll the larger injectors ??
and use some sort of adjustable ignition driver to adjust the timing??
it will onli be for a few month to allow me to run the car while i save for standalone..
i'd say do it once do it right.
get yourself some omex/emerald and go from there. If you lean-out and screw the engine you've just built your going to be upset
yer i supose your right mate, how much should i look at paying for a decent ecu ? im open to ideas on makes and models ...
Depends what you term as decent and what functionality you require. VEMS is a surprisingly accurate and very cost effective solution. Usual suspects of Emerald, Omex, Link, Motec etc. will all run it without a problem and probably do all that you requrie and more. Anything above that (i.e. Life, Solaris, Pectel, Bosch) will be well past £2K.
M
