Right, so, I'm afraid it's another 'Vs' tyre thread...
I have a new (to me) RWD car. It has come with mix-and-match tyres on all four corners. I have zero drifting skillzzz as I've not had RWD before.
I cannot decide which would be the better option:
- 195/50/15 Dunlop Sport BluResponse @ £198.
- 195/50/15 Michelin Pilot Sport 3 @ £228.
Generally good user reviews exist for both:
http://www.tyrereviews.co.uk/Tyre/Dunlop/Sport-BluResponse.htm
http://www.tyrereviews.co.uk/Tyre/Michelin/Pilot-Sport-3-PS3_1.htm
One of the 'proper' tests says of the Dunlop:
Another test says it is as sharp as the award winning ContiSportContact5 in the dry:
Alternatively, several comments on the PS3 reviews link above mention "driving in the wet like it's dry", which is echoed by the AutoExpress test:
I'd like to be able to explore the limits of RWD handling when safe to do so (perhaps damp, quiet roundabouts out of town) so I actually learn how to drive it properly, but I prefer rock-solid stability when there's standing water around and for when I make a mistake (which I am sure I will do at some point).
For the former, the "weak lateral [wet] grip" of the Dunlops sounds appealing, but its reduced ability during aquaplaning is a bit of a worry as I'm not sure I could rescue an unintentional 'moment'.
For the latter, the PS3s seem to be wet weather gods, but will they be so grippy as to stop me exploring the limits and learning how to drive properly?
If anyone has driven on either (or both?) and can offer any input, that would be smashing.
(And yes, track time will be on the agenda at some point as I don't want to be a loon on the road.)
http://www.tyrereviews.co.uk/Article/2015-Test-World-Summer-Tyre-Test.htmThe Dunlop Sport BluResponse has good braking performance on wet surfaces, but relatively weak lateral grip. The tyre resists aquaplaning, but in an emergency situation are a little nervous. In the dry they demonstrated rapid response to the steering and were well controlled during emergency manoeuvres. Very quiet and low rolling resistance
http://www.autoexpress.co.uk/accessories-tyres/91860/dunlop-sport-bluresponse-reviewIt was second around the handling course, where it had the sharpness of the ContiSportContact 5, but needed a touch more lock through the tighter turns. And while it was less effective in the aquaplaning assessments, it was firmly in the closely matched mid-pack.
http://www.autoexpress.co.uk/accessories-tyres/91861/michelin-pilot-sport-3-reviewStandout performance is the remarkable superiority it showed in aquaplaning. The tests often have a wide spread of results, but the Pilot Sport was a clear victor on both – particularly the tricky curved test.
It was close to the front in the shallower-water tests, too, taking just over a second longer to lap the handling circuit. Turn-in was eager but it began to run wide mid-corner, sometimes triggering the stability control. It felt secure and tackled the final 90-degree turns without lifting. While it was two metres off the best in the braking, if you tot up its percentage scores in our wet road tests it was second only to Continental overall.
