i dont think the miltek decat will fit a standard system either unless it comes with an adapter? i guess a reducer will need making up to get you onto the pipe after the v flange from the decat.
you need a decat like the one in the link below with a standard exhaust without cutting/welding/adapting.
you will need to take it to a place that can cut a section of pipe out and put a couiple of new joins/clamps in. yes it can be done. it will work just the same as a decat thats a straight fit, infact its an advantage having a miltek one as you can use it if you upgrade to an aftermarket exhaust, on a downside, your standard cat will not just fit back in without another pipe/reducer being made up, if you ever need the cat back in that is.
i dont think it worth the faff no. i think as you said, you are better off selling it and getting one thats made for the standard system. straight simple swap then with no real hassle as such. only swapping it back for mot.
btw, if you are selling the miltek one, pm me. i might be interested.
lol! given it some thought and it will be too much hassle for me to have it pres. the back end of my cat is chopped to 2.5" bore, so i would need an adapter making up.
