Help needed for a problem i cant locate.
clio 1.4 2003. When started with a cold engine in this weather it ticks over at 600rpm'ish with a shocking misfire. Will occassionally fail to keep itself running and stall, at which point will require a good 20 seconds of cranking before it fires back up.
If you hold the revs at 2000rpm for a minute or so and allow it idle it will drop to 1400rpm and be fine, once warmed up no faults whatsoever.
Fault code has picked up zero faults and spark plugs appear in good condition/normal colouring. Reoccuring fault getting more and more common.
Any help is appreciated, thanks.
