Misfire cylinder 3- p0303 options?
  A45 AMG 406BHP
Hi
The 182 received the following fault
Po303- misfire on cylinder 3
Sounds like its running on three
it runs but badly
I removed spark plugs to find the 2nd n third plug wet ( petrol)
I think it's coilpack- do coilpack a fail in two or single?
Am I safe to turn over the engine to check spark with inlet off?( don't want to mess up other sensors)
  Clio 172 Cup, Volvo
Just out of interest my 172 had a misfire on no.2, took it to Fred at BTM who diagnosed plug leads. Try them first.
  Megane r26
Could be the coil pack cause cylinders 2 and 3 do spark together (due to wasted spark ignition) but first off try sparking it off the inlet, swap leads to just to makesure its not them
  A45 AMG 406BHP
Sounds like a motorbike- misfire on cylinder
182
originally got fault code po303 misfire on cyc 3
Changed
plugs, leads, coiloack new
Idles level but sounds like its running on two/ three
Now I'm getting misfire on cyc 2
What is going on?
What else should I try? Injectors?
Ideas?
jenic
  981 Cayman
Re: Sounds like a motorbike- misfire on cylinder
Injector?
Get it on a decent code reader before spending more.
  A45 AMG 406BHP
I haven't got a decent one
only BMW one which won't work
I've changed injector from cylinder 4 to 3
and still misfire on 3
I will stick the injectors in cups and turn it over to make sure there all firing at same.
jenic
  981 Cayman
Pay someone to get it on a decent code reader then, for the sake of £30 at a specialist it would be well worth it.
Try diamond motors.
  A45 AMG 406BHP
Not insured, I'll have to ask around.
After injectors, could it be lambda precat one?
Cheers.
