Misfire
Car  Clio Sport 172
Yet again another problem
Spun up yesterday morning and suddenly started to misfire after that.
Changed all leads coil pack and plugs still misfire I believe it could be injectors but its not multiple injector is it? Haven't had a proper look at it yet!
Any help would be greatful as not a fan of a CRV aha
Platinum Ngk they were misfiring on the old ones as well going to have a look a wiring today any more ideas would be great
Update: played with the wiring to the injectors fired it up and was running fine played with wires again and went funny again and couldnt get it back gun a try it again after work will take it off and are if I can see a split or if it was just when I was cold it was fineMore ideas would be helpful cheers
Which wires did you play with near the fuse box by any chance? I had an issue like that a while ago and it was dirt connections at the fuel pump/injection relay.
