M3 SMG
				Hi,
Reading a few threads on the search funtction:
http://www.cliosport.net/forum/showthread.php?t=485943&highlight=missfire+lambda&page=2
Similar problem to me!
Car kept throwing an eml every now and again with no real effect on the car as such. Got garage to read the codes..
Post cat lambda was problem. Car is fitted with sports cat and upon inspection the lambda had been blanked off and was strapped to the side of the exhaust which had then melted :nono:
Garage put the front sensor on the rear, and ordered a new front one. Picked car up all seemed fine
1day later:
 Started hesitiating when pulling away from roundabouts, and withing minutes eml was flashing like made and the car sounded like a diesel spitfire. Shaking and popping.
Blatently a missfire i struggled home and called the garage. They suggested to bring it back and have a looksie. I was convinced that being the lambda was the only thing changed that it MUST have been the issue. They wouldnt even look/check it out. Just said it was a mechanical misfire and likely to be plugs/leads/coil. They read the code but all that came up was missfire and no specific code? (Not a Renault Garage)
Changed, the coolant temp sensor the other day, and then the garage changed the coil to no avail. So im now utterly stumped as to the problem.
Plugs/leads likely? I didnt think they even needed changing to 70 odd k, mines only done 39!!
Whos are best ot get Renualt or other?
James
1day later:
James
