black 172 phase1
:dapprove:car recently had coil go ,so sounded like tank anyway replaced and car still sounds like rough idle ,also sometimes car just starts and stalls even if foot on pedal for a few seconds,replaced tdc sensor,water temp sensor, leads, coil,oil change and filter ,fuel filter ,got new plugs but shop only had super plus bosch in stock,cleaned throttle body and idle valve, car has whats only to be described as a pulsing idle, revving itself,idle drops quite low then back to under 1000,the car was doing this before coil went so ongoing problem.
mate used snapon solus and no codes so no better off ,anyone on here got an rs tuner chelmsford way that i can sort em out for using on my motor,anyway thanks for reading any help welcome.
