As long as you have the mounting points, you wont need to change your door, if you didnt want to change the doorcards you could always just put a plastic bung where your winder used to be.
A tip for you, when removing window/motor, spray a bit of WD40 on the little white clip at the bottom where the glass in attached to the regulator, makes it come off a lot easier!
