Depends what type. A decat plus straight though exhaust similar to Big Iain is probably the most powerful but noisy.Quote: Originally posted by IsvenII on 20 July 2004
if i could only do 2, which is better? a sports cat + exhaust system (minus the centre pipe) or a cat-back system?
it was better but constant failures led to renault ditching the idea.Quote: Originally posted by IsvenII on 20 July 2004
I understand that the mk1 172 cat has 2 pipes compared to jus 1 on the newer models. Is it a better cat compared to the new models and those aftermarket ones?
what failures were they? btw, what you guys reckon with a panel filter + supersprint exhaust system? i do not need a chip with those mods heh?
You dont need a remap but due to the low fueling of the Stock 172 it will gain power and remove the worries (Id have) about lean running.Quote: Originally posted by IsvenII on 21 July 2004
