mk1 & 172 head units and cd changers
Hi everyone!
Will the cd changer from a 2002 model Clio 172 work with the head unit from a Mk1? Will it plug straight in? If not, then is there an adapter available?
If it wont work, and theres no adapter, then can a 172 head unit be put into a Mk1 and still retain all the controls? I.e. are the plugs the same?
Thanks,
Scott.
Will fit its a special connection not the common cd changer connection you probably used from Pioneer or Sony but this is a special cable just like 4 little wires bundled in a handyman connector from renault. Looks very simple.
There are three connector on the backside of the headunit. 1 is for the steeringcontrol, one for the illumination in the mid console and one for speaker/voltage.
cheers
What I want to do is take the factory changer out of a Mk2 and put it in a Mk1. I need to know if the connections are the same. So if I take the Mk2 cd changer out, will it plug into the Mk1 head unit, or did they change them when the Mk2 came out?
Are the radios and/or connecters the same on a Mk1 and Mk2?
PS: The head unit is just marked renault and the factory changer is marked renault/alpine.
Scott.
If I had it, I wouldnt have asked here...
...but I dont, so thats why I need to know. Its actually on behalf of someone else that wants to buy the changer from my Mk2 but he has a Mk1.
Scott.
Ok, in case anyone else was wondering, both options are possible - the head unit from a mk2 will go into a mk1, and the cd changer from a mk2 will work with the head unit from a mk1. This is from the Renault spare parts people.
Scott.
