hi folks, i had bit ofa search but couldn't find what i was looking for. I apologise if i seem a bit dim and the answer is staring me in the face.
I fitted Dual optics into my Mk2, and did the wiring change to let them work (albeit still havent managed to do the relay bit) my question is:
Do these only have the Vertical adjustment wheel? i have 6000k HIDs in them as the standard bulbs were rubbish, however i have a suspicion they're shining just a little high in the air above dead ahead, i've had to put the adjsuter wheel onto 3 or 4 so they're shining enough on the road - i also don't want them shining through someone rear windows and blinding them (they are in projectors though!). When driving down the road - you can very clearly see the blue illumination from them on road signs wayyyy down the road.
I had a look under the bonnet and saw the white adjuster cog on them, i was going to park up against a wall and adjust them down more - is there only vertical or do these also have horizontal adjustment? Just in case they're too far off to one side.
Should headlights be shining slightly down to the road, i.e. /not/ dead ahead? also: do you have to re-align headlights every time you remove/replace bulbs?
thanks guys!
thanks guys!
