Was going to remove my Diamond Renault badge for a carbon finish.
just wondered if anyone has removed before and how the front and rear badges come off?
I never did do the front but I'm lead to believe it involves removing the bumper, the rear is easy, remove the interior boot trim and you should be able to push the expanding pins from the inside, the badge also then comes apart
Yeah I've heard that the front comes off when the bumper does, but I've also heard that you can do it without taking the bumper off!?
confused!
&thanks dude!
I don't but to be honest the bumper removal isn't all that difficult, you just have to be prepared to put the time in just to take the badge off, as a touch guide the best way will be to get the front on axle stands and take the wheels off, remove the wheel arch liners, they should just pull out with the clips, then inside the wheel arches you should find one or two nuts/bolts on each side of the car connecting the wings to bumper, remove those, then there's a few nuts/bolts underneath I think, get rid of those and then the 4(?) bolts underneath the front of the bonnet, then you should be able to do a bit of jiggery pokery and remove it, lay it on a towel or something and set about removing the badge, I don't have any instruction for that as I haven't done it but I'd bet it's pretty obvious once you're looking at it hope this helps
You can wrap it on the car if your good enough. Also, biohazrd did a bumper removal guide in the guides section....actually i wont be lazy....here it is
