More bloody knocking!!
  1.8 Civic EX
this one has me well and truely baffled...it's not the strut top knocking i don't think..the noise is too "solid" if you know what i mean.
passenger side front wheel area. only does it when reversing on almost full lock right hand down??
here's the even more confusing thing...it only seems to do it when cold. ie; it did it just now as i pulled out of the parking bay at work, i got home to a nice big area and tried reversing in all directions and at different angles and it didn't do it???!
  1.8 Civic EX
really?? maybe not fitted properly? it's been doing it for a fair old while but it was really bad today...wonder if i let the car warm up before i move if it will still do it...
  Astra VXD xp with DTUK
if its like what happen to mine i.e caliper lost 1 of bolts the noise will get louder in time, i was baffled for ages to and only figured it wen other bolt came and whole brake assembly fell apart, my bro in laws 172 did excatly the same thing
ideally would be easier to take the wheel off and see if the caliper swings away from the pad carrier because the calipers are pretty close to the wheels. see if theres any score marks on the inside of ya wheels or even if the caliper is resting on the inside of the wheel or put full lock on and see if theres bolt missing from the caliper
  1.8 Civic EX
typical! it didn't do it this morning lol had a quick look and there is no sign of the caliper being loose. Hopefully get the wheel off tonight to have a proper look.
Anything else it might be just in case?
  182, 172 Track Shed
Ive had the exact same problem but even worse!
On full lock (or even alomst full lock) forwards or backwards i get this pretty nasty knocking/rubbing/grinding noise coming from the front somewhere Id say.
Its definately much worse when the car is cold, and doesnt seem to tbe there at all when the car has had chance to warm up. Ive had it into Renault dealer twice who say they have modified the suspension mounts but this hasnt fixed the problem at all. Also I was told that this wasnt covered under the normal Renault warranty and I ended up paying £90 for the work!?
Anyone any ideas what else this could be and how I can check for it?
Car is a 54 reg 182 btw.
Cheers!
  Bg182 bitsa,thisthat
well hope i can help ive got exact same prob car has been in fr 2 weeks and is coming back tomorrow.. 05 reg 182 cup.. think you,s may wont to look towards your gear box, when its cold the dif is locking common fault i think but will let you,s all know tomorrow
davo172
  TCR'd 172
Try your front antiroll bar bushes the outer ones where they join the front arms either swap em or grease em . worth a try, they only cheap . Cured mine.:D
  1.8 Civic EX
mine did start after i smashed a curb preety hard ???
lol, certainly been no curb smahing on my part...
I'm thinking it's the seexed Diff sugestion...since I put this post up it hasn't done it, it was any of the other sugestions I would have thought it would always do it!??!
Plus it's not been quite as cold here in the mornings recently
well scrap the diff idea new box in and still the same, ive now had a new hub new bottom arms new drive shafts and new gear box,, all new new not 2nd hand the search contines... any 1 had any look with it yet its defo alot worse in cold
add strut top washers to the list, still no diffrent... going to take the whole front end out on wed night c if can find any thing:dapprove:
  Meg 230 R26 F1
dont know if this helps, but i had a knocking noise coming from front passenger wheel area...turned out to be a ball joint with too much play...not too expensive to change and has fixed the knocking completely.
your cars not as old as mine but might still be worth checking if you havent found the cause of the knocking...
good luck
