right, ive got everything wired in, and everything is working how it should apart from the the 2 smaller headlights, nearest the grill. they just dont do anything! any ideas on what the cause could be please?
If only the main lights works, then I suspect that you have connected the yellow wire on the left side and the blue wire on the right side (I hope your wires are coloured the same) incorrectly.
The yellow wire should connect to the white wire of the left main light.
The blue wire should connect to the black wire of the right main light.
hhmmmm dont think mine look like that! i do have spare yellow wire, with nowhere to plug it in, guessing that has something to do with it!
did you get a connector on yours to hook over the live terminal on the battery??
