Morettes,need help connecting wires!
Has anybody fitted these or know how to wire up the inside of the 2 lights which are the main beam lights!!
Smokey
I dont have just a white wire, i have a white with green stripe, red with a green stripe and a black which i know is the negative! But how do i connect them to the positive?
Sorry just not very good at electrics!!
  clio 20v
yeh its the white one with green stripe that is the wire for the main beam u just wanna splice into that i assume
dont have em and never fitted em so couldnt really say u not get any destructions with em
adi
  BMW 320d Sport
Errr when I get my Clio back Ill have a look. I remember the instructions werent very clear on that point. But basically you want to splice a wire in so that when you switch your main beams on it triggers the inner pair of lamps AS WELL AS the outer normal lamps switching to main beam.
Yeah thnks guys, thanks Nick Read that would be great, i didnt get any instructions as i bought these off of e-bay!!
smokey
Ok then as no one can really help me, does anyone know where i can get the instructions from so i can try to figure it out!!
Sorry to be a pain in the ass
  clio 20v
just thort on, the max power clio haynes manual has a section on fitting morettes if i remeber rightly, shud hav one at halfords
ill try an find the one i bought see if i can tell u a bit more info on fitting
adi
  clio 20v
right according to the haynes book the original lamp plug should go straight on the quads an there should be 2 spade connectors that go into the sidelight wiring plug
the white wire with green stripe goes to the yellow wire on the quads
the grey wire is an earth and needs earthing, there should be a wire with inline fuse that goes straight to the battery
its not rocket science hehe;)
