At the risk of firing the parts cannon - which of the above parts would likely cause surging on very light, constant throttle?
ie, cruising in 5th at 60mph
I've done the basics, leads, coil, plugs and also changed MAP sensor and cleaned throttle body.
I wonder if the sensor in the pedal is at fault, although can't see much evidence that these generally fail.
