most weight carried
Car  ph1 clio 172
hi i need to get 30 bags of sand/cement (25kg each), how many at a time would i be able to get in my phi 172 , it has gaz coilovers so i can stiffen them up first
cheers j
i had 5 tins of metal billets in mine, i would say each was about 45kg, That was on standard suspension and it was lowwww
just over a thousand thompson local books in the back of my old 1.2, it was slow enough without the weight (yes in hindsight it may of been too overweight :S)
400-500kg? that mad! Our old berlingo works van only carried 500kg, you would be mad to put that much in a clio. 10 bags max IMO 250kg
It would be extreme, but I've had 5 big lads in mine, one in the boot, and it's not struggled. It was low though. Lol. 15 bags at a time should be fine
lol at 500kg. thats 5 circa 16 stone blokes in your boot. pmsl.
I have had 450kg of people in my car before, was fine for half hour, took it easy obviously lol!
Who cares??
Just fit as much as you can in. I've had my van (renault trafic) scraping the floor carrying decking out of the yard. They offered to deliver but I showed them fcukers!!! (How to ruin a van.)
its not just the weight side of it , its the police side as well dont want to get nicked , but 12 bags at a time spread around the car should be ok
some funny tales though
j
Who cares??
And you showed how to get a £1000 fine for yourself and £1000 fine for your business + 6 points on your license for overloading.
I had this lot in my clio. It sure was low. Not sure of the weight though.
Ask someone with a bigger more practical car? I got my Dad to come and pick up some paving slabs for me as he has an L200 so made life much easier.
if yout going to do it then remove the rear seats,, keep the weight infront of the back wheels and over the wheels if needed.. any weight over the back of the boot ( behind rear wheels) will lower it far more than weight in front of the wheels.. hope thats makes sense..
ie.. dont put it on in the boot it will be to low.. try to spread the weight between the front and rear wheels
makes perfect sense. over rear wheel only rear suspension will take the load. before rear wheel the front and rear suspension will take it ;)
lmaooo. I had my saxo lowered 60mm on rear, and had 6 people in the car. any bump and it scraped, who cares do it till you feel thats enough, 3 trips tbh should do it.
i will see your 6 people and raise you a leather couch;
LOL @ the fork-drill! Never mind scraping your own arches etc, just remember to brake early enough to avoid scraping anyone elses property!
Circa 1670 KG with your proposed 500 KG of cement plus yourself... no thank you :o Anyone who remembers Newton's second law from physics will realise it'll take you roughly 50% longer to stop from a certain speed.
EDIT: Nevermind, I see you're in Norwich, meaning you probably won't be crashing into me.
