CLIO 182 CUP
need some help.
i've failed the emissions test by a big amount see results below:-
FAST IDLE TEST....... LIMIT ........ACTUAL
CO....................... 0.3%vol .......8.36%vol FAIL
HC ........................200PPM .......362PPM FAIL
Lambda ...................1.03........... 0.76 FAIL
now the thing is its just had a full service 3weeks ago which was spark plugs, oil, cambelt and timing belt and also had a new ktec ultra performance exhaust.
The car runs great, it's not lumpy and its not misfiring.
so since the MOT yesterday i have had a full diagnoses on the car which showed no faults.
i also took the cat off and it looks clean and it isn't blocked.
therefore has anyone any ideas what the problem is because i'm totally baffled. could it be the lambda sensors???
the test centre may have performed the test when the car was cold making it fail its test but this wouldn't make a massive difference to the results would it. i don't want to get the cat really hot just to pass the test because i really want my car to be right
any help would be much appreciated
Thanks in advance
Thanks in advance
