ph2 172
Hi all,
I had a MOT yesterday, the car failed on 3 points.
A cracked front spring, number plate bulb and the the bit im writing this post about - Parking brake mechanism/associated mounting area is fractured.
I asked what this was and basically where the handbrake is attached to the car has come away. They're fix which they wish to carry out tomorrow is to remove the seat and carpets and weld it back. I didnt really like the sound of this so when i got home I phoned a mechanic friend of mine, he had a look and said its not fractured its just the bolt that holds the unit to the chassis (which is spot welded at manufacture) has detatched.
My friend removed the bolt and put a new one in. So my question is will the garage get funny about the repair and fail it again even though the unit is now safe?
Oh and how much should I expect to pay for the spring + fitting?
