MOT Help Please
Car  ph2 172
Hi all,
I had a MOT yesterday, the car failed on 3 points.
A cracked front spring, number plate bulb and the the bit im writing this post about - Parking brake mechanism/associated mounting area is fractured.
I asked what this was and basically where the handbrake is attached to the car has come away. They're fix which they wish to carry out tomorrow is to remove the seat and carpets and weld it back. I didnt really like the sound of this so when i got home I phoned a mechanic friend of mine, he had a look and said its not fractured its just the bolt that holds the unit to the chassis (which is spot welded at manufacture) has detatched.
My friend removed the bolt and put a new one in. So my question is will the garage get funny about the repair and fail it again even though the unit is now safe?
Oh and how much should I expect to pay for the spring + fitting?
depends where you get the spring from mate, but it shouldnt be to much tbh, will take less than an hour to fit
Spring can be had for about £40 new.
Though I daresay you could get a pair from on here for about £20 if your looking for OE.
Euro car parts are around £40, and the garage said it would be around that too so ill just let them crack on with it!
It seems quite common for the bolts to come loose on the handbrake, as a said above aslong as its all nice and tight and work how it should it will be fine.
Good luck with the re test.
Carl
