Taras2016
Clio 172 cup
Hi everyone just wondering if anyone has a me360 ecu fitted on there clio 172. as just looking for some advise.
basically ive just fitted a new me360 ecu and carried out all the pin swaps as per the instructions from motorsport electronics and i have come a across a issue where when i turn the key i get no crank it seems to try but not fully engage the starter i have checked all the earths and power supplys and relays which are fine. if i bypass the starter relay it will crank as normal via the key. it seems to be a issue where the uch is not providing the ground for the starter relay to switch. so i think its something to do with the immobiliser no liking the aftermarket ecu. the dash is showing a solid red light which i believe means it has accepted the key but for some reason it wont allow it to crank.
has anyone else had this issue and how did you get round it.
thanks
thanks
