Mounting Sidemounts without Subframes
  #174
Is this possible/safe? There's 2 bars that run along the floor which the standard subframes bolt on to. I'm not sure if they'd fit but if they did would this be ok to do? If not some adaption bars could be made so that they would I reckon.
  #174
Cheers, I'm guessing there's probably not a safety issue with doing this. Only thing is they might sit pretty low. If they're not the right width I could use 2 flat steel pieces and bolt them to the rails on the floor and then bolt them to the sidemounts.
