Mouse jiggler
It will just show up as a usb mouse, so unless they've locked it down to only being able to use supplied mice it will work without a problem
Didn't even know such a thing existed.
Why wouldn't you just change settings to not go into sleep or screen saver?
Always befriend the IT guy and get local admin rights.
This
The hoops I used to jump through to get certain software installed.
Whereas now I just go to my man Phil and he sorts it for me no bother.
Personally i've found putting the mouse on a watch/clock and let the ticking move the mouse, gets round the audit logs of usb being plugged in/out and can usually be picked up for a few quid
It's not one person, it's a whole team.
And?
You gain the trust of one of the team, they set you as local admin, you can install what you like on your local machine only, and it's still governed by group policy.
Anything else needs global admin.
In hilton I was made local admin by one guy, got a new laptop, a second guy made me admin again.
When I got sacked the IT manager accused me of using a 0 day to elevate myself 😂
It being a team means nothing.
I just had their trust, and they would rather I just done it than asking them to remote on every time.
Anyone use such a thing?
Am worried it won't work on my council computer where everything is locked down
depends what policies have been deployed but councils and basically anything public sector usually have appalling device management/mdm and IT in general. So it’ll probably be fine tbh
Andy this is good advice,
Put the mouse on top of your wife's vibrator, they will think you are working overtime.... or have terrible Parkinson's.
Open teams and put something heavy on the ctrl key. A stapler works perfectly 👍
I just leave my teams as offline nowadays! It literally drives me insane with constant bull s**t messages, being dialling in unannounced to a conference call. I struggle to keep up with my email traffic, if people need me my phone is always on.
I prefer something a little more eloquent - save this in a notepad file on your desktop, rename it to (whatever).ps1 then right click>run with powershell.
This keeps your screen active and stops Teams going to "Away"
Code:
# -- NoSleep --
# Keep your computer awake by programmatically pressing the ScrollLock key every X seconds
param($sleep = 240) # seconds
$announcementInterval = 10 # loops
Clear-Host
$WShell = New-Object -com "Wscript.Shell"
$date = Get-Date -Format "dddd MM/dd HH:mm (K)"
$stopwatch
# Some environments don't support invocation of this method.
try {
    $stopwatch = [system.diagnostics.stopwatch]::StartNew()
} catch {
   Write-Host "Couldn't start the stopwatch."
Write-Host "Executing ScrollLock-toggle NoSleep routine."
Write-Host "Start time:" $(Get-Date -Format "dddd MM/dd HH:mm (K)")
Write-Host "<3" -fore red
$index = 0
while ( $true )
    Write-Host "< 3" -fore red      # heartbeat
    $WShell.sendkeys("{SCROLLLOCK}")
    Start-Sleep -Milliseconds 200
    Write-Host "<3" -fore red       # heartbeat
    Start-Sleep -Seconds $sleep
    # Announce runtime on an interval
    if ( $stopwatch.IsRunning -and (++$index % $announcementInterval) -eq 0 )
        Write-Host "Elapsed time: " $stopwatch.Elapsed.ToString('dd\.hh\:mm\:ss')
Code:
# -- NoSleep --
Clear-Host
$stopwatch
try {
} catch {
$index = 0
while ( $true )
Just open up notepad or word and put something heavy on the spacebar. Works a treat and best option.
or open powerpoint and press the presentation button in the bottom right corner. You can then alt tab to teams.
I am so glad I work somewhere that I don't need to worry about any of that horseshit :LOL:
Not even ready the rest of this but I can't imagine working somewhere that I have to do something like this. Mental really that people either don't like their job enough or get watched enough they have to do this!
I can give you a batch file that hits whatever key you want every X seconds, and doesn’t require admin writes to run.
Used it it at a very secure client once…
Are software restriction policies still a thing? Using those almost 20 years ago now would stop stuff like that running ;)
In general, any access to the command prompt is disabled for a local user by almost every group policy.
In my current role, I can't access cmd, but have ssh access to a Linux box with no restrictions, heh.
My previous role, I had cmd/ps access but couldn't access as administrator, meaning I couldn't really do much.
I wasn't allowed to run any non approved executibles.
The rule before that blocked it all, approved installs were hosted in the software centre, until I was made local admin.
I WOrK FrOM HomE anD DO mOrE THaN I WouLd In THe OFfice....
Enters a nut and bolt.
Councils running out of budget, cutting people's jobs and public services.
Meanwhile public sector workers sat around at home wiggling mouse about trying to look busy...
Guess it all adds up.
