Mr Clutch, Crap
Clutch cable snapped last week so got a new one fitted in Mr Clutch (bollox). After having this fitted, the car wont go into reverse without crunching and its a b**ch to drop down a gear when slowing down, almost have to hammer it in!
Took it back to Mr Clutch, explained problem and they said I need a new clutch, without even looking at it!
The car was fine b4 the cable snapped, so r Mr Clutch trying to rape my ass?
Nothing wrong with your clutch probably mate.
More likely to need adjusting, usually on a ratchet system on most cars but dont quote me on a 16v. I havent messed with mine coz to be honest im quite scared of bolloxing it up!
Sounds like Mr Clutch wants you to be his b**ch, hence tell him to nob off
I hope your right , coz I dont really wana be paying out for a new clutch! Costs a bloody fortune!
I am a bit concerned about it now coz the problem seemed to correct itself after a day and then started up again yesterday. Its got me baffled!
Yeah matt, sounds like its inbetween 2 teeth on the ratchet.
Try pressing the clutch to the floor then releasing it fast a few times. Otherwise go see a decent mechanic you trust and he should help you out but a doubt you need a new clutch....
sniff i had this same problem mate, My cable snapped friday night, got another one fitted and now I cant get reverse at all! dropping down gears is nigh on impossible, took it back and they said the thrust bearing is f**ked and its time for a new clutch, boohoo :(
When my clutch cable snapped on my williams, i got Renault to fit a new cable. I had trouble getting mine into gear as soon as I left the car park. Turns out the clutch needed replacing (which is why my previous cable snapped). I got a clutch from Mr Clutch, and it lasted me a couple of years (low mileage). Bloody thing nearly caught my car on fire when it burnt out on the M25 last year. Got Renault to replace it with a pucka one. Would never buy a patent clutch again.
  300bhp MR2 Turbo
Got my clutch done at Mr Clutch in January £293.52 cheapest place by a long shot.
Mine def needed doing though as it broke appart and came through the inspection plate stopping the engine from starting!
Know what you mean . I actually had a garage fit me a patent clutch , even though I expressly told them to fit a genuine article only. Result = 6000 miles on the next clutch before it broke whilst the original renault unit had lasted 80k miles and done loads of track days .
Stear WELL CLEAR of cheap clutches on quick Clios
Cheers for the help guys, sounds like I need a new clutch then!
Is it normal for the clutch to be very stiff on a valver or is that a sign!
