My 182 alarm beeps three times
  Renaultsport Clio 182
Sometimes when I lock my car using the remote fob, the factory-fitted standard alarm beeps 3 times (as well as the usual flashing hazard lights). It seems to happen every now and again and I can't figure out why it happens. The manual isn't written very well either. Anyone know the answer?
  Ford Focus ST2
use the search,
many posts about this!!!
had mine done under warranty, but it still does it!!
So what does the three beeps mean? I've done a search, and found other problems, like people's alarms giving one long beep, etc, but nothing specific about 3 short beeps.
Even sometimes when I sit in the car for a while after the ignition is off, then get out, close all doors, then lock, I will still get 3 beeps. Like I said it happens once in a while, so I am clueless.
  Clown Car
I think the 3 beeps means you have de-activated the interior sensors, sometimes if i switch my ignition off and immediately get out of car, shut door and press button on the key it will beep 3 times, iirc the alarm supplement says to deactivate interior sensors you switch ignition on/off twice then get out and immediately lock car and it beeps 3 times.
Or is it the fault where the alarm still thinks it has an ignition feed?.
Just rang my dealer about it and they insisted I book it in for them to have a look at. No one had a clue what it might be. How frustrating. Is it worth me booking it in? So much hassle! I said I will ring them back on monday.:dapprove:
  MY10 R35 GTR
mine on the odd occasion does it, I just gp round give the doors and boot a quick open and shut check everythings cool
  MK1 Clio 16v
I think it's something to do with the head unit earth? I think it earths to the same point the ignition earths to, and it makes the alarm think there is still an ignition. My friend has this problem on his 182 and got it fixed under warranty.
Could be wrong though..
  182 - conneries de c
Mine does exactly the same, beeps 3 times when I lock the car quickly after getting out. If I wait 20 secs or more from turning the ignition off to locking the car it doesn't.
Quote -
"Another common problem is when you lock the car the alarm beeps 2 or 3 times.
Reason: The alarm system has received a signal from the vehicle ECU that the ignition is 'on' causing the alarm to beep. This signal is only received by the alarm for 3 to 4 seconds, after this time has elapsed the alarm stops beeping.
Solution: It can only be resolved at a Renault dealer. Ask the dealer to contact the 'Renault alarm help line' and quote reference
'RS+15'
If I recall correctly from previous threads on the same subject it doesn't stop the alarm working but is more annoying in nature, personally I like it beeping.
No harm in getting Renault to check it out when yours is in for a service etc, assuming that its still in warranty?
  V6 255, 172's, JCW,
'RS+15'
No harm in getting Renault to check it out when yours is in for a service etc, assuming that its still in warranty?[/QUOTE]
Hi Jeffer.. this is the most correct qupte so far on this thread fella. IMO
Had exactly this happen to mine nearly 2 yrs ago. Had it fixed under warrenty at the dealer where i bought it from, something to do with a relay incorrectly wired up. Was only a small job to put fight.. about 20 mins.. and that was the first time they'd ever done it! Not had any problems with it since either.. Just get it booked in if it annoys you.
Shaun
:S
i'm not convinced they actually did anything(they never fixed anything else it was in for). it still beeps at me sometimes, but after leaving my car at a different garage 3 times in the last couple of weeks i'm not too bothered about it at the moment. just have to get used to waiting a few seconds before locking it until it annoys me enough to sort it out.
  silver cup packed FF 182
was reading up on this lastnite in the renault alarm manual anyone else read it,there series of beeps on the alarm apparently that beep from once to seven times?!?
^^yeh, there a warning to tell you something has happened, but theres a fault with some of the alarms that causes this 3 beep thing
Thanks for all your posts. I don't think I will take it in to get it looked at especially. I will probably just mention it the next time I take it in for a service. From my experience, it doesn't matter how long you leave it from turning the ignition off to arming the alarm. I've sat in the car faffing around after I've turned the ignition off before getting out and locking it and it has still beeped 3 times.
