my car needs lowering.... what to go for..
Here she is, if I just buy springs the shocks are going to get knackered, but I can't stretch to coilovers....
Im thinking a full Apex -60mm kit with shocks, any other suggestions? KTEC do one called 'ulimate' is this any good?
Alex
apex 60mm kit sounds spot on to me. don't buy coilovers as they're just a fancier more expensive option that are only really worth the buy on an RS and not really needed on a 1.2 tbh
With a 60mm drop your allows will rub. I have a 40mm drop and they did rub a little on full lock until i removed wheel arch liners
If the wheels are the right offset and tyres the right size then 60mm should be no probs.spax do a 60mm spring kit for about £100 but then your faced with destroying the dampers over a period of time but if you have the money buy the kit.Apex will give a slightly softer ride than spax but it will still be quite solid.
I diddnt think there was a problem getting full lock with a -60mm on full lock? ie no rubbing without changing tyres or taking liners out
Will they really rub, the alloys are only 15's, the tyres are quite high profile though, they are pretty much the same rolling radius as the 14" steelies that were on there before....
