small guide because blue makes you happy :approve:
At first you have to abolish your dashboard. If You need help for that i will post too if required. Then plug of the two (ore four) Clips rearside of the Speed indicator.Turn in on the top (the olde one are locadet with screws) and now put them out. Now you have the several speed indicator unit. Plug off the front clear-view screen. Its only clipst. Afther that, unscrew the torxscrew (smal size) on the rear side so you can plug off the rearcoverage. Now you have to plug of the needles. Mark the zerro position thats important!
Use a prong ore something like this and leveragecarefuly the needels from driveshaft.
Now you should plug of the speedindicator-disc and so you can see the smal SMD LED on the plate. You have to soldering them of and blue ones in. The Type of SMD LED i will give you next time.
Its verry ambitious to soldering SMD LED because there are verry smal and dosn't tolerate high heating. Important is also the polarity of SMD LED they are marked. So if you don't trust ask friends how has done that once again more than you
Middle Display.
Thats a little bit more tricky. Disassembly the radiodisplay module on the top. Plug of the clips on rearside.
Now you have to open it. If its open put off the lights. Plug on the two clips rearside again and take a multimeter. Measur for the positive and the negative voltage on the lightbase. Mark that, thats important.
Now you need a peace of board. Cut this board so that its compatible to put it into the the White box. It should have 1cm (1/3") to the rearside. Now you need an Plate in Germany is called "platine" i dint find the correct translation. Cut the plate on the same metrics like the board.
Next you need aggain SMD LED. Took the same like them from the Tacho. Now you have to soldering small stands on the SMD LED so you can install them on the Plate. Fit four in a elektronical line. So you didn't need an resistor. Fit 12 SMD on the plate always 4 in line and than these three Groups connecting by soldering parralel. Check the polarity and solder them on one of the Lamp sockets in right polarity. The other soket isn't need no more times again.
Take the orange lensdisc and use sandpaper with 800 graining ore more to grind the orange color from disc After that use an abrasive an Water to get the disc like milkey.(Fore the speedindicator needels you can use by original in red ore make them milkey too) Now You need diffusionfoil. You can buy at Ebay. Cut them convenient to the frontdisplay. I use two kinds of diffusionfoil. One normale kind and one witch is adhesive. I took thes together behind the frontdisplay.
Now glue the plate into these White Box.
Heating:
For eachone wich have no ore manuel air-conditioner its abominable to plug of thes Part. Im afraid but i can't remind on each Step. But you have plug off each coverage and then unscreaw the screws at the Top. Then you have to turn the Heatingcontrol panel and hang out the, in German we say Baudenzüge. Also there are an clip witch you have to plug of. And then its the same Prozedure like the middle display. Cut a Board and then build your plate for SMD LED.
Also you have to build off each orange splitting disc in the panel and in The turningswitches. For rotary switches use a nipper. Now take a wood glue. Thats a glue witch is white when he is fluid and clear-transparent if it is dry. Mask the holes on the turningswitches and put in the glue and blue LED (not SMD for turning switches only)
Now solder all bye the same way, 4 LED ore SMD LED in line and than built Groups witch are soldered paralel.
Now it should glow blue :approve:
Fore each Switch resolder the orange LED and fit in a blue LED with a new resistior. Its easyer than it kooks like.
The Radio
i bought a new blue one
Greatings from germany
So, genug englisch nun gibts für mich ein Bier dann meine Frau und dann das Bett
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
