Black Gold 182FF
Noticed over the last couple of days that the temp gauge hasn't reached midway on my drive to/from work, which seems unusual (I know it's a bit colder at the moment, but even so...). So today, I was up a little bit earlier and decided to take the motorway to work. After 5 minutes of motorway speed driving, the temp gauge had barely reached the first notch, and then as I pulled off onto the slip road it dropped down to just above the bottom. Seems very low to me, even given the lower ambient temps; I'd have expected it to be almost at running temperature by then?
Doesn't seem like a coolant temp sender problem as when I've had that on previous VAG cars, the gauge has wavered around between normal temp and zero, over and over. Mine seems quite steady, just very low. Are F4Rs known to have thermostats that can fail open so that the coolant is taking the "wrong" path round the engine and keeping it too cold?
