My Clio Track Car Blog
  CTR--VX220D
Thanks guys!
Just took my badges out of the heater - looking dappa :)
Will fit them tomorrow after work ;)
Just need to get my straight through Yozzasport Ranotti fitted now!
  CTR--VX220D
Thanking you :D
Had a little play with a std [I think] cup today [naughty me] and it pulled away nicely... cant wait to get it on the track and dyno'd.
  CTR--VX220D
Yes.... the 172 it pisses on it.
When I said 'it pulled away nicely - I meant My 172 pulled away from the Cup nicely/quite easily!!!
  Z4 Roadster
^lol!!
badges look much better and inkeeping with the dark wheels. :)
be interesting to see how the track day goes. Did I read your blog correctly, in that you'll be doing two different types on the day?
  CTR--VX220D
Yes there are two courses running at the same time. Should be interesting! :D
Its an ideal event for open wheelers hence a few caterhams and westies, but I shall have alot of fun trying it out. There are also a couple of VX's going - will be great to see them again.
I need to get my tracking done beforehand though as my wheel is not dead centre.
  Lionel Richie
chris can i suggest that you put the lower platform back on as it locates the rear spring, your current setup is a bit dangerous (thats why i didn't take it off)
  CTR--VX220D
I still have the threaded chamber that is bolted in place - the springs are located over these - they cannot dislocate due the length of the chamber. Even when I jack it up the springs do not pop out excessively.
See:- [car jacked up when taking pic]
Thanks for your concern though Fred :)
  Z4 Roadster
jeees, you ever go to work man???
silver paint paint isn't exactly much of a clue / hint when you've got a silver car!! :rolleyes: :rasp:
Chris you want those mounts putting higher up as per this picture otherwise you'll injour your back in a crash as it pulls you spine tight.
