My Clutch is being a b**ch.
every now and again when i press the clutch peddle down it clicks and the 'Biting point' chanes to right up the top nearly all the way up
Then bit later it clicks again and 'biting point' changes to right down the bottom. it also doesn't feel like the clutch is coming all the way up ( when its at the top )
Some of the teeth on your tensioner are broken.
Common failure its a bit of a apin to chnage the ratchet have a look around your foor well you'll see how it works and how to replace it.
  BMW M3
I once had this prob on an old escort. Ended up being a a little nylon cog type thing but was a mare to replace.
  clio rsi!
i found it easier to take the drivers seat out completely to get underneath lol very fifddly but doesnt take a genious to work out what to do
