i'm pretty sure on old versions of windows you could put a wallpaper on the background for your my documents.. can you do this ox XP? if so, how? thanks
i'll have a play but in your my music folder the background is different to the my documents so must be there somewhere. although if you were meant to change it you'd of thought they would make it slightly more obvious.
got mine working, heres how its done, click start, control pannel, appearance and themes, choose a screen saver, on the normal drop down bar to select a screen save you should see my pictures screensaver.
To configure a background for Windows Explorer toolbars, perform the following steps:
*Start a registry editor (e.g., regedit.exe).
*Navigate to HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar.
*From the Edit menu, select New - String Value.
*Enter a name of BackBitmapShell, and press Enter.
*Double-click the new value, set it to the name and location of the bitmap file you want to use for your background (e.g., c:\windows\zapotec.bmp), and click OK.
*Close the registry editor.
