I hate to think what I've replaced on that saxo, theres a thread on saxperience for it. The list of things is about as long as my arm. I think the only original drive line component is the steering rack!
Whats the spec? Is that the posi blue 1.4 one?
Rough spec to mine:
s2 rallye j cammed 1600 8v, 4-2-1 and supersprint race section with scorpion imola (I kept the cat in)
s1 rallye gearbox
apex springs up front and shocks, spax adjustables at the rear, ds2500s and new oem discs all round
gti rear beam setup
half rollcage, cobra clubmans
PC'd 205 gti wheels with new GG 888s all round
plus a refresh of most the other drive components ie: arms and trackrods etc
Yeah it's a 1.4 furio, we've barely done much to it at all as we didn't really want to spend alot of money on it, it was just something to get us into motorsport with a view of getting something quicker after a couple years and eventually end up doing track racing somewhere down the line.
Got bored tonight and thought what can I do? saxo has no new parts to fit so I looked on top of the cupboard and noticed a powerflex lower bush I ordered ages ago for the Clio. Was easy to fit however had to engage the brain as my vice didnt open wide enough - stilsons, old sockets and once bent vice handle later and the bushes were out.
Fitted it to the car from starting in about 30 minutes and makes a real difference! Shift is much more precise, theres slight vibration on idle but nothing I'd call excessive after reading threads on here and obviously this will settle down in time. Also it appears to have cured a "knock" I had going from rolling backwards to a stop when applying the brakes.
Time for a curry and beers now!
Will definitely be popping the equivalent on my saxo now, for the money the difference they make is great
Changed the gearbox oil again today for the 3rd time in about 3 months! Was waiting for stock of total 75w80 as no where seems to stock it round here and I needed another litre of it. Wasnt happy with the comma stuff in there, but I've kept it as its only done circa 300 miles so its been stored into a clean container and I'll keep it for the track car
One now oil filled 1980s stew pot:
Now all thats left is to polybush and powerflex the saxo, then help my mate build up his Metro GTi VVC. Busy few days ahead!
After powerflex bushing the saxo last friday, I came across another set of trophy dampers on fleabay, won them so off came the non-OEM cheapo dampers and on went the sachs gear. Really stiffened the rear of the car up, much more confidence inspiring when driving quickly I find plus they are a touch stiffer than cup spec dampers I believe.
Unfortunately due to delays with brembo I havent been able to fit the discs I ordered as they havent arrived yet.
I've fitted a new revised design top mount, probably didnt need it as one of the brake disc securing screws fell out when I took the wheel off which was probably the cause of the "clack" when stopping in reverse but I thought I might as well renew the old stuff.
new track rod ends - old ones werent too bad but might as well do it, only one pic of this sorry about the quality
Bled up the brakes and replaced the old fluid with some Motul 5.1 fluid as used in my track saxo. The old stuff was well past it, probably original as it came out the colour of Real ale!
Easy enough to bleed up with one of these jobbies!
Hopefully I'll secure some brembos when people have them in stock then I'll be able to fit them along with new OEM pads.
Brembos came today from G172 - gotta say thats top customer service as I only paid for them yesteday about 3pm. I've just been out bedding them in and the brakes feel really sharp now with nice bite as I've put in new OEM pads too as well as the new fluid from the other day . Also tried the Mintex Ceratec brake pad lube instead of copper grease as it supposedly better over time and with higher temperatures:
All fitted
I also cut out some matt black vinyl for the bumper inserts as the originals were all cracked and falling off:
Just keeping it in reasonable health to be honest, oil change is due soon. Maybe a damper refresh at some point or powerflex bushes but I'll see about that
Should hopefully make the exhaust look a little less like its drunk and last a bit longer - the standard ones had given up and the rubber spans had mostly snapped.
Also changed the front lambda sensor as I was only getting 25 mpg tops. Reset it and went for a quick blast and it seems to be hovering around the 33-35 mark now, just have to see how that goes.
Old gearbox mount was shagged as can be seen here, so I changed it. Kept dropping the bloody bolts from the mount itself, can be a pig if they drop down onto the subframe! Should be captive nuts but anyway its done now.
Just done the offside wishbone balljoint on this as it was looking crusty and wasn't as tight as I'd like. Hate doing ball joints on these though, saxo is so much easier!
New thermostat and coolant went in today, nice and easy job. Now my gauge actually sits in the middle as it should. I tested the old stat and it didn't seem to be stuck open at all however but never the less it went in the bin
Gave it a full clean yesterday, all the arches washed out with pressure washer and the lips cleaned with a toothbrush. Got it up on ramps and did the whole underside with the pressure washer. Then it rained so only one picture, but its nice to know all the road salt from the winter is off it
The purple van the followed me turned round and they picked the camera up before I could get back to it. Luckily I managed to chase them down and demanded the camera back off them - guess they didnt want reporting to the police as it was a works van.
company number ison the side of the van, not sure if anyone can read it but their reg is too. Am debating what to do about it as I did get the camera back but it was still attempted theft.
I can, got the HD video at home so i'll have a think.
Yeah they couldn't reverse due to the silver van. I thought it odd when the silver van came up the road and the blue one didnt, so shot back to find them driving away and the camera had gone. Glad they gave it back however without too much fuss, theiving knobheads!
@imprezaworks - the camera was on the edge of a laybay on a small tripod. Its only a small camera so I'm not really sure how they spotted it, guess the passenger saw it as they were 3 up in the front
Thanks guys, just glad they didn't put up a fight really as there was 3 of them and one of me but never the less it turned out ok. Next time I'm taking a camera minder!
