Well so far no good! I have downloaded VMWare player trial which is OK. However I wanted to build a 2008 test server with the 180 days trial and didnt know 32 bit support has been removed my laptop has a 32 bit cpu!
You'll be needing emulation not virtualisation then. I use qemu under linux to do this, not sure about gui's as I just use it direct from the terminal.
So using emulation I trick the OS into thinking I have a 64bit cpu? I have no experience with linux so I dont know how far ill get.
Does it need to be 2008 R2?
Initial release 2008 can run on 32bit, only 2008 R2 is 64bit only.
