My Wheels Wont Stop Rubbing!!!
hi! on friday i had 16" 172 alloys fitted to my mk1 phase 3 clio 1.4 rt!!
i also had the front lowered 35mm and i think the back was lowered about 60mm! the wheels were constantly rubbing against something when i had any1 in the back of the car, and so i took the plastic bit from under the arches out as it was definately rubbing against it!
but now it is still rubbing aginst something, but i dont know what!! any ideas?? its only on 1 side of the car!!
please help!!:mad:
60 on the rear ?? why ??
put talcom powder over it then take it for a drive, where its all rub'd you will find your answer
You will need spacers as the 172 wheels are ET 43. They must rub on the inside of the arch. 5mm spacres might cure the rubbing.
