My windshield washer jets are spraying any washer fluid on to screen. Any ideas?
  Renault Clio 1.2 16v
Clio mk2
1.2 16v
2005
When I do use the washer function, a very little amount of water comes out the end of the jets, but just falls down the bonnet. A bit like a not quite turned off tap.
I’ve tried to use a pin to clear any blockages but nothing came of it.
the pump definitely works as I can hear it when I’m using the function.
any idea what it could be and is it a big job / expensive one?
ex-Chinese Dave
Any fluid? lol
I think there is something inside the fluid bottle that can block, a filter of some sort. Have a search on here as I think it's a common fault.
Not a Diesel!!!
  LY Meg Cup-S + MX5
Clio mk2
1.2 16v
2005
Prop just need new washer jets.
Just did one on MX5 earlier this year. Bit of a pain as windscreen scuttle needed removed.
I think there is some kind of valve in the jets that can get gunked up.
Andy_con
  clio 182
needs the rubber bung trimming, full guide in the guide section ;)
common problem of the rubber expanding over time
