n/s driveshaft fitting.
Car  www.renparts.co.uk
anyone got a guide on doing this for a 1.4 16v mk2 clio? Also what are the shafts like from GSF? are they reconditioned? or blueprint?
ta
josh
which side is near side?lmao
cos i did my drivers side one myself and it was a c**t cos i didn't have a clue what i was doing
The near side is a bit of a pain you've got to drain the gearbox.
Shouldn't take more than an hour and a half.
1) Remove the 30mm nut in the center of the wheel 9or least loosen it off)
2) Drain gearbox of oil.
3) Jack car up and remove wheel
4) Undo the bottom ball joint two bolts (infact might as well change ball joints when there off)
5) Remove the 30mm driveshaft nut
6) Pull the suspenion shock outwards make sure you can push the driveshaft out (use a hammer is a good idea to kock the shaft out otherwsie the shaft moves with the hub).
7) Undo the 3 bolts which hold the driveshaft gainter to the gearbox.
8) Remove driveshaft
9) put it all back to gether in reverse order and refill gearbox (preferably when whelel is off and car jsack up to check the gaiter isn't leaking.
