Nasty noise when locking drivers door....
Car  172
After a few ideas that may help me here please!
I have had my alternator replaced today (after dieing last night), and since i have had my car back when i lock it it is making an awful screeching noise, as if it is catching or not quite connecting somewhere. It is still locking though. I have had a look at the lock and the bar in the body, and i cant see any obvious faults, i also lubed them a bit in case that was the problem, but it hasnt helped. It opens fine, and the passenger door is fine. I have run out of ideas now, any help very much appreciated.
Cheers all, sorry about the essay!
Jon
Cheers Jay, is that much of a job to replace? It has only just started making the noise, before it was fine/normal.
you would need to remove the interior door panel and then the lock mechanism so you can change the solenoid. easy enough job though.
