2005 Clio 182 FF
Here was me thinking Id have it done in a hour and be in the pub for a pint :S.
Anyways the driveshaft splines are seized into the hub, So far methods employed:
Bottom ball joint undone from wishbone, track rod end let go. Full Lock.
Bearing pullers (Broken)
Lump Hammer (Not a budge but a seriously fucked up shaft now).
Next step is Heat the hub which I presume will screw up the wheel bearing (Im not even sure my LPG blow torch will be able to heat it up enough).
Then if that fails:
Undo the hub from the shock and pull the whole show out including the shaft, f**k it in the bin?
Any better Ideas? Seriously pissed off with this.
Then if that fails:
