Need coilovers OR decent spring/daper package. ideas?
  • Thread starter Thread starter mini-valver
  • Start date Start date
  • Tags Tags
    oil
M
mini-valver
Need to sort the suspension on my car, Ideally obviously coils would be great but TBH a decent spring and damper kit would do, Koni's or similar. Looking for around a 60mm drop but want the back to go down too as my current springs just arent low enough at the back and it's really light around bends.
Wouldnt mind adjustable damping but not essential. Looking to spend about £3-400...
They are for a 1.6 16v ph2, anyone know the correct bolt spacing?
you need to measure the bolt spacings as they vary. but ring john @ 2modified for some FK's, as the ride quality will be far superior than dampers and apex 60mm springs.
Will do, just enquiring as I was impressed with your KW's! Koni adjustable dampers on springs should be better than fixed rate FK's though right?
i loved my FK's on my 1.2, far more than i love the KW's. benefit of the FK's is that the dampening was spot on for road use in my 1.2, height adjustable and camber adjustable for £420. cant argue imo :approve:
