need HELP asap! (ice install!)
Just been tearing my car apart to fit my new alpine x100 to find the following problems:
- my glove box has no hole (like people said it should) to feed the ipod wire through.. should i just drill one?!
- the steering stalk control adaptor i bought seems to be the wrong model or im fitting it wrong, as i have no idea where its menna fikkin go!
Cars in pieces atm really just wnna get this all fitted! :(
Hey guys. new ICE has been wired up. Took me nearly 4 hours but it was worth it as im 100% done a proper decent job.
Now to just find that pesky steering wheel adaptor!
  Focus RS Mk1
I have my cable fed to under the little 'ash tray' which removes with a simple little pull. under there ive fed the cable to my USB. i dont need to touch that unless i wanna update it. little different from the ipod. but just a suggestion :)
Yeh i had my last headunit wire coming out from there, but that was because it was just a normal AUX in so the ipod had to be in a place where it could be used at any time. Since this one allows you to control everything from the headunit i decided to put it in the glove box, as the ipod isnt completely hidden in the ash tray and tends to stick out a bit.
  L'arctic Bleu Clio 182FF
Fancy putting up some pics mate? would love to see it! What have you done with stalk adapter? I take it you removed standard Renault one, and that your set up doesn't work with dash display?...
that drill looks a bit flash too! can it drill through most substances?
Well i have the stalk adaptor, just need one more wire to make it work as i bought a wrong part. Ill get some pics up soonish hopefully.
  133, 182, Kangoo 182
I have two holes right in the top of the gloveback. One is where some models have a light and the other I don't know. Pretty much right at the front on the top.
Well mine has been dremeled into the back far right corner so you cant see it unless you are a very nosey passanger! lol
