So have a clio with a leak from the crank seal behind the flywheel. I know I can address this by removing the subframe, gearbox etc and installing it with the engine supported from above.
It's done few miles so the tensioner/idlers/dephaser will be fine, but the cambelt is just over 5 years old so that needs done too. I have no qualms at all about doing the job and I've seen all the warnings etc.
Question is, am I best to approach these as separate jobs, with the engine in the bay, or does the combination mean its worth removing it? If so, out of the top or the bottom?
What would you do, and what else should I consider doing whilst I have access?
