Need your help
Car  Clio b phase 1 Sport
Hello mates.
I have a strange problem at the last half a year,I don't know what to do.
Ok,the car is Clio 172 Phase 2 2003.
Done 100K,engine checked good working condition.
Half a year ago I drove to work and a coil light went on the control panel.
I stopped the car,turn the engine off waited a few minutes.turn it on again and light go off.
It happened a few times but nothing serious.
After a while the light go on again,I tried to accelerate but the engine won't go over 3,000 rpm no matter what.
At night the lights go on automatically,I start the car push the accelerator but nothing happened.
The car is running but no metter what I do the rpm won't go up,700 rpm.
Connected the car to a computer and the fault was the throttle.
I took a throttle from my firends car,and nothing changed.
Swap the ECU,coil pack,leads,alternator,
accelerator pedal,ignition.
Checked all the electric,even got a mechanic throttle and it pedal and still the same problem.
Don't know what can it be.
Coil light is for the ignition system and the injectors... try swaping out the injectors if you havnt already, otherwise it sounds like a problem with the loom
Replaced all the ignition system.
Injectors didn't check.
Seems like an electrical problem.
Loom checked seems to be ok.
limp mode that is its the electric fault warning light mate.
