Donny_Dog
Jim's rejects
The management has approached me with some info.
We access a system on someone elses network that uses a 172.248.x.x address range (Their network is massive) and we connect into it via a 10mb point to point leased circuit.
Our network is also massive and uses a 192.168.x.x address range. up until now its been pretty straightforward. the relationship is one way E.G we access the resources on their network and they do not access ours.
The info I was told today is that their 172 network is going to be re-i.p'd to the same as ours. :S
We still need to access these systems after they have been re I.P'd and the management has said that I need to provide them with what I need to make it happen.
As it stands we have a cisco 1841 router at the edge of this 10mb circuit and I created a static route to their subnet and then published it within R.I.P so that all our clients from our large internal network can route succesfully. I can't exactly do this in the new world when their internal addresses are the same as ours. So somehow I need to deploy NAT.
I've got plenty of Cisco routers spare (the 1841 version in abundance) and a 3500yl Layer 3 switch should we need it.
My plan is to deploy NAT on the 1841, to NAT our 192 range to (lets say) a 212.148.55.x NAt pool. I'd then tell their network bods of my plan so they could amend their router at the other end of the 10mb circuit to point the range back toward us.
I have no control over their network, so I don't know what is at the other end of this leased connection! all I know, is that it works at the moment.
Is that the most reasonable way of completing this? Does it make sense?!
