Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Ok, done that. Manually put in the dns but still no luck. Laptop works fine and connects to the internet.
Could it be the firewall on my laptop? Would it stop the xbox connecting through it? I have just thought of that? I have the xp firewall and zonealarm, but I think I turned the windows one off.
I've spent the whole weekend re-booting every thing in different orders lol. I thought if the ICS gave the ip, then it should give the dns, but on testing the connection on the xbox, it confirms ip, but fails on the dns.
if so then it sounds like you have a routing issue. The packet being sent to the DNS server is either not getting to the DNS server or the return packet is not getting to the xbox. You need to figure out which first, then you can fix it from there.
Yes I can ping the xbox. I have no idea what to do if it's to do with the router itself, but I will try turning off the firewalls to see if that helps.
