new bits and pieces
  16v 1.6 Clio MK3 GT
figured i would post this in as it is quite amusing. i may as well have bought a new car all the times i have repaired the clio haha:
done mods:
blue footwell lighting
custom dash job (blue lcd display as opposed to orange)
custom drivers switch for footwell lighting
additional boot light
done repairs:
4 new spark plugs
left rear seat belt retaining clip
right rear seat belt retaining clip
new alloy wheel
4 tyres
new front subframe
2 front springs
rear axle
rear bumper
rear brakes
2 rear springs
2 rear shock absorbers
front brakes
thermostat housing unit
lambda sensor replacement
drivers wingmirror mirror
cigarette lighter bulb
heater controls 2 bulbs
drivers side airbag cables (annoying airbag light on dash error)
front drivers side shock absorber
air con refrigerant renewal
front passenger side track rod
windscreen washer pump
horn connections cleaning
rear highlevel brake light
front wheel bearing
new windscreen
front drivers side main bulb x 2
steering wheel alignment 4 times
passenger side rear wheel arch bodywork pulled out to correct shape (slight dent)
gearstick gaitor glued back on
what can i say, it will not die lol. been in 2 crashes and still she lives!
  16v 1.6 Clio MK3 GT
something i sent to someone else:
hi mate, they're the black bits on the top of the seat to just hold the seat belt in position. why the clios have them i dunno, they also lower the seat down for access into the boot. if that's what your on about, i got the them from cit-ren near where i live, an auto dismantler specialised in french. pretty easy actually. pull the seats down, unzip the seat back and then use long nose pliers to remove the push in button and seat belt holder.
because i needed to get a new speaker cover grille i kinda just pocketed them at the same time, lol. cant see both of them being more than £5 together tbh.
