new center consol cover
i am wondering if it is possible to get a new cover for the center consol on a 04 clio dynamic 1.2? my mate has a corsa B and got hold of one easy and cheap, and it fitted relitivly easy as well. At the moment it is the normal black but i was wondering if you could get silver ones, or white? ive seen the stickers you can stick over to give it that effect but i can amagine it would look tacky and start to peel after a while.
cheers
shaun
  Chocolate Bar™
wouldnt use the stickers, because IMO they look really cheap and quite nasty (especially if theyre off centre)
if your going to do it though, id use a sheet of carbon fibre (which will be difficult to cut nicely, and will take some time)
otherwise, spray it. ill probably be doing mine soon, but arent 100% positive how it comes out as ive not looked.
Mark
Its held on by clips. Just get a flat end screwdriver and carefully prize it away from the dash. The clips are fragile so be careful
